quick?
Old May 12, 2012 | 09:39 AM
jonbonesjones's Avatar
Moderator
Default quick?
where is the ecu connector i need pin 17 yello wire for the fuel sender
i know where the ecu is but in relationship to the interior i have the knee bolster off and can see all the relays and all that **** I'm assuming its behind that. just need to know where to tap.
Old May 12, 2012 | 05:48 PM
mtroxel's Avatar
If you know where the ECU is I'm not sure what you're asking. The ECU is in front of the windshield just beside the brake resevoir...and the connectors are obviously right there. So you must be asking about something else?
Old May 12, 2012 | 06:02 PM
Moderator
well the interior connectors pass through the firewall I'm just wondering if which ones go to the ecu theres a **** ton of wires down there does it all go to the ecu? i like to have an idea of where to go before i tear into it. that always ends up bad
Old May 13, 2012 | 10:23 AM
mtroxel's Avatar
No easy answer to that one. Many of the sensors in the engine go right into the ECU harness, some of the relays wire into it....
You probably need a Bentley with wiring diagrams before you rip into that. You don't know what to test for unless you know what is what.
Old May 13, 2012 | 04:17 PM
MetalMan's Avatar
You could've asked
The ECU connector itself connects to the ECU.
The other wire I mentioned that I snipped is only accessible from the top of the ECU box (behind the ECU).
Old May 13, 2012 | 09:22 PM
Moderator
hahah thanks. I saw a car with the ecu removed in the junkyard today and discovered the answer. now which connector? it says longer connector pin 17. I'm assuming its obvious when i get in there.
Old May 13, 2012 | 10:14 PM
MetalMan's Avatar
I think it will be pretty obvious. There are 2 connectors that hook up to the ECU, and one is longer than the other.
Old May 13, 2012 | 10:18 PM
Moderator
awesome thanks for the help. did you wire your radio into the cluster?
Old May 13, 2012 | 10:33 PM
MetalMan's Avatar
My aftermarket radio doesn't offer that functionality. Otherwise I would have.
My stock radio wasn't all that great... the CD changer would skip any time I went over a bump.
Old May 13, 2012 | 10:37 PM
Moderator
i have an alpine im thinking of switching to syphony to get that feature. i might wait for my rns-e before i dick with all that. having the nav info in the MFA is the shiznit
ryanwpl
Feb 27, 2009 03:07 PM
Blue01TT
Aug 21, 2008 06:55 PM
CamoA6
Jun 27, 2008 06:18 PM
khj677turbo
Dec 23, 2007 06:00 PM
mrhurst88
Apr 12, 2007 08:24 PM
