Radio "SAFE" Mode
Old May 20, 2013 | 06:42 PM
power moves's Avatar
Default Radio "SAFE" Mode
I currently had an issue with my radio going into "Safe" mode and when searching for a answer notice that this is a common occurrence. The "stealership" wanted to charge me $130 to look up the code for me, even though I already had the serial number. Ridiculous. I found an easy remedy without having to leave my house.
You will need:
VIN# and
Radio Serial#
If you are already in possession of the radio serial number (if not you have to pull the head unit, it should be located on the side or top of the unit)all you have to do is call either:
1-800-367-2834 or
1-800-822-2834
Press #3 and then #1.
Both are numbers for Audi of America.
They are very polite helpful and it is FREE!
Good Luck.
Old May 21, 2013 | 05:15 PM
SquishyPanda's Avatar
I'm going to have to try this. I've been dreading having to disconnect the battery for any electrical work because my car's previous owner doesn't have the code.
Old May 21, 2013 | 05:46 PM
PoormansAudi's Avatar
Also, if your radio has ever been replaced the code will be - 1111
I can't tell you if my radio has ever been replaced but can tell you the code works on mine.
Old May 21, 2013 | 09:15 PM
Mad Cow's Avatar
Not true, even reman radios have their own unique code.
Is the serial number all you need? This seems way too good to be true.
Old May 22, 2013 | 03:11 PM
Serial # and VIN #. The serial # so they can provide you with the code and the VIN # to prove you have ownership of the vehicle
Old May 22, 2013 | 03:42 PM
Can you source that opinion?
According to this article it is true. To save the trouble of viewing the link the following is a quote from it.
"Some remanufactured radios are hard coded from the factory with 1111 so you may want to try this code first. "
Old May 23, 2013 | 08:47 AM
CCA4's Avatar
That doesn't mean ALL. I've purchased and installed two OEM remanufactured Audi Symphony II radios and neither of them used 1111 as the code. In both cases, the code came printed on a new radio card that was included in the box.
Old May 23, 2013 | 09:36 AM
Agreed, I have no doubt it doesn't work on ALL, the point of my post was that it's worth a try.
"Some remanufactured radios are hard coded from the factory with 1111 so you may want to try this code first."
Old May 23, 2013 | 10:47 AM
Mad Cow's Avatar
Also bought 2 reman radios, a Symphony I and II, both had a unique code. I think it's more common for them to have a unique code than just 1111, maybe radios rebuilt by whoever does it for Audi have a unique code and ones rebuilt by other companies have 1111.
So I guess the phone number is too good to be true, can't exactly get the vin number of a reman radio or one you got from a junkyard or part out. Oh well, I guess this EEPROM programmer I bought won't go to waste at least.
Old May 23, 2013 | 11:38 AM
CCA4's Avatar
Or you could just take 5 minutes and call AoA and get the right code for free.
