Raising the WHP bar
Old Mar 5, 2011 | 10:39 AM
  #41
bradtyler02's Avatar
That's what we all thought, Don...
Mike, you're still having tranny problems, right?
Old Mar 5, 2011 | 05:34 PM
  #42
Msnickbroderick's Avatar
Actual WIZARD
I hate to gay it up, but wouldnt a level 10 autotragic hold it all down?
Old Mar 5, 2011 | 06:20 PM
  #43
chocalotstarfish's Avatar
Super Moderator
His new tranny holds it all.
Old Mar 13, 2011 | 01:06 AM
  #44
BlueBoostedaudi's Avatar
I have a problem. My 2001 1.8t AWM won't start. The regular belt turns but the timing belt doesn't turn. It looks like the bottom timing belt gear that possibly goes to the crankshaft is spinning. Is it just a bad timing belt? Do I need a new head? Can I bolt a aeb head to my AWM block?
A
Old Mar 13, 2011 | 11:34 AM
  #45
Mike-2ptzero's Avatar
Well you will need see what is broken and fix it. Also need to pull the head and see if any valves are bent before buying another head.
Yes you can bolt a AEB head to a AWM block.
Old Mar 13, 2011 | 06:24 PM
  #46
It was my timing belt
Old Mar 14, 2011 | 08:45 PM
  #47
It was just my timing belt when I tried to start it all the teeth on the crank shaft got pulled out got new timing belt in but I think the timing is off cuz it has a ruff idle and sounds like crap. I lined up the top camshaft line w the block line and lined up the crankshaft line w timing belt cover line am I missing some thing? Should I run a lil advanced timin? I'm running peak 17-12 pounds of boost at redline w water n methanol injection and 98 Oc. How much timing is safe ?
Old Mar 15, 2011 | 08:38 AM
  #48
Super Moderator
When the timing belt goes we have interference motors so the valves then get bent. I'm not sure if you tb failed or not but that's why mike said to check the valves.
Old Mar 15, 2011 | 08:48 AM
  #49
agreed... depending on the conditions, you probably bent some valves and/or messed up the pistons.
Old Mar 15, 2011 | 08:55 AM
  #50
CCA4's Avatar
god dammit can we stop bumping this thread? Everytime i see it at the top I get excited for new turbos and dyno sheets and video goodness, and everytime I'm disappointed
