Really? a better k03 for AEB b5 a4 1.8t
Old Feb 13, 2013 | 08:45 PM
NLT1.8T's Avatar
Default Really? a better k03 for AEB b5 a4 1.8t
I have been searching around and have found myself a bit confused about the k03-05 and k03-29. Did kkk make a k03 turbo with a more efficient compressor wheel for 1.8t longitudinal? If so, what year, engine code, bolt on? I apologize if this is a really old horse that i am whipping. Also, i'm not trying to make big power gains, just wanting to replace an old worn out turbo on an apr chip daily driver. I have read about rebuilding into a hybrid, but cast of turbo has some cracks. Long and the short, is there a better k03 to replace stock aeb turbo? Any input would be appreciated!
Old Feb 14, 2013 | 06:35 AM
bradtyler02's Avatar
the '01 had a KO3s, which is more efficient.
Old Feb 14, 2013 | 07:56 AM
redline380's Avatar
Legal Moderator
this is a common misconception. there was no such thing as a "k03s" made for longitudinal, or as far as i know transverse engines. the email from borg warner is floating around here somewhere. i do believe the turbo was revised for 01's, but it never recieved the nomenclature of k03s. 01's had more power from the factory because of revised tuning and added boost. its why a chipped 98 will make the same/near the same power as a chipped 01.
look at it this way. if you put a turbo from an 01 on your 00,99,98, or 97, it won't make any more power
Old Feb 14, 2013 | 05:49 PM
NLT1.8T's Avatar
Ok thanks for the help. I am going to look into rebuilding longitudinal k03 with transverse k03s turbine and compressor wheel.
Old Feb 15, 2013 | 07:29 AM
Makes sense...
