Rear caliper questions . . .
Old Sep 15, 2010 | 02:13 PM
eelpie's Avatar
Originally Posted by bradtyler02
Someone correct me if I'm wrong, but the front brakes do most of the work, and unless you're doing some hard braking, the rear brake pads don't really contact the rotors as much, which could lead to a little rust on the rotors.
The rear brakes do about half the braking of the fronts, give or take, but there still shouldn't be rust on the area of the rotor swept by the pads.
Old Nov 4, 2010 | 09:12 PM
t_andrews's Avatar
I've seen rocks or road debris get lodged in a pad and act like ceramic wearing away rotors leaving grooves. When they wear down or the foreign bit gets released, the pads then have a high spot and can leave rusty rings until the pads wears the rotor down.
If the rust is all over the swept area of the pads, you could have a collapsed line internally, or seized pot in your caliper.
Chances are you'd feel a little 'squirrel' action on hard braking though.
audivalley
Jul 26, 2012 01:19 PM
audivalley
Jul 24, 2012 09:30 PM
mandito219
Feb 3, 2009 08:09 PM
kakarot
May 4, 2007 01:51 PM
cdnskier
Sep 16, 2005 06:16 PM
