Red Antifreeze
Old Aug 12, 2008 | 06:48 PM
beem's Avatar
The problem with switching to green is you have to change the stuff every two years to keep up its protection which costs in time and money. As I understand it Audi says the red is permanent. And mix with distilled water so you don't add any unwanted minerals with the tap water. B.
Old Oct 23, 2008 | 12:48 PM
anmagro's Avatar
I know i am bringing this back from the DEAD but how much of this G12 do i need for a total refill?
Old Oct 23, 2008 | 12:53 PM
anmagro's Avatar
http://www.blauparts.com/proddetail.asp?prod=G012A8D
how many of the 1.5L jugs that blau sells do i need^
Old Oct 23, 2008 | 12:57 PM
A4 Effort's Avatar
Bone-dry after a coolant drain you would need about 3 of those. Just go to the dealer and get a gallon, costs about $25 iirc. You'll also want to do a 50/50 mix of coolant and distilled water.
Old Oct 23, 2008 | 01:05 PM
anmagro's Avatar
Dam, ya see thats my problem, im at school and i dont have time to go to the dealer, and online it looks like im gonna get raped with the shipping, it came out to almost double the cost of the collent its self.
Old Oct 23, 2008 | 01:17 PM
A4 Effort's Avatar
Eff that - call the dealer and check their Saturday hours. Some places keep their parts department open till noon that day
Old Oct 29, 2008 | 07:21 PM
anmagro's Avatar
So...slight update on the coolent change. Heres the deal.
1. Unscrewed Engine Compartment Refill Cap.
2. Unscrewed Gray/Black Coolent Spicket from Drivers Side
3. RED fluid started flowing out
4. Cleaned mess
5. Only got about a 1 and 1/10th of a gallon out of the Spicket
6. Mixed Audi dealers Pink G12 coolent 50/50 mix and poured in a gallon.
7. Capped it up, first drive, ok.
8 Second Drive, coolent went below min mark and got a warning light.
9. Spicket was tight.
10. Topped off and now im ok.
What happened? Was i saposed to be running the car as i filled up the coolent?
And another thing. The spicket at the bottom only gave me about a gallon and a little bit, but yet i poured at LEAST a gallon and a half in on the refill. Did i do something wrong?
Old Oct 29, 2008 | 07:46 PM
  #18
Dallas09's Avatar
You have to open the drain plug on the coolant pump also (and on non-AEB engines maybe a few other places if you tell me your engine code i can find out). This will drain quite a bit more out. The reason the level dropped is there was air in the system and then when you ran the car the air came out of the lines.
Old Oct 29, 2008 | 07:57 PM
  #19
anmagro's Avatar
Out the lines? ****. Am i gonna have a bunch of leaks now? How do i find out my engine code? The cars not with me now.
Old Oct 30, 2008 | 01:17 PM
  #20
anmagro's Avatar
Anyone?
