Removing fuel injector rail
Old Mar 4, 2011 | 08:48 PM
jdahlen24's Avatar
Default Removing fuel injector rail
Hey guys,
I'm in the middle of replacing my valve cover gaskets and cam chain tensioner seals, and things are going pretty well.
The problem I'm running into is that the fuel injector hoses on the passenger side are right in the way of getting access to the cam chain tensioner seals, as shown in the pic below.
Can I safely remove the fuel injector rail and thereby move these hoses out of the way to get access to those seals? Is there a certain procedure I must use, or can I just unbolt the two bolts that hold the rail in place?
I'm leery of just removing them and seeing what happens, as that could be a recipe for disaster without knowing the possible consequences.
As always, many thanks for your sage advice!
Old Mar 4, 2011 | 09:10 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
This should help: http://www.audiworld.com/tech/eng.html --> Replacing Fuel Injector Gaskets
Old Mar 4, 2011 | 09:46 PM
jdahlen24's Avatar
Thanks lm!
I could have found that via google, but I appreciate it just the same. I was actually looking for assurance that this is no big deal, and that DIY gives me that assurance.
Old Mar 4, 2011 | 09:50 PM
I figured since I haven't removed my own fuel rail, I'd be better off leaving that determination up to you.
Pepsi_son
Dec 16, 2013 12:50 AM
shane.trammell
Jul 12, 2009 01:18 PM
gabeguimaraes
May 23, 2009 06:54 PM
MULEPERFORMANCE
Sep 11, 2008 12:22 PM
kraylon
Sep 7, 2007 12:02 PM
