Replaced Alternator-Still not charging
Old Aug 19, 2010 | 07:52 PM
Audi Tek's Avatar
Tech Certified
there is a wire from the alternator to the instrument cluster called an exciter wire.... which triggers the battery light.
Just a little FYI for future reference
Old Aug 19, 2010 | 08:19 PM
onepoint8tee's Avatar
Originally Posted by tanrichguy
Ok i have the car running. You were right onepoint8tee, the battery was indeed bad. I replaced it and now have the alternator charging properly.
Thank you again for your help!
Aaron
Cool!
Old Aug 15, 2016 | 08:35 PM
Voshmag's Avatar
Default Anybody figure this one out?
I am having the same issues, alternator reading bad, so was starter. Replaced alternator with aftermarket sub from advance for my bosch. Reading at idle from alternator is 12v and voltage regulator is reading bad. Got underneath and cut open my block to body ground and it was fried. Replaced that and was super hopeful. Nada, same problem. Thinking abut replacing the positive battery cable bit it's 300 bucks. Don't want to take a shot in the dark if I don't have to.
It is pretty odd that the same alternatpr that another member bought from advanced is doing the same thing.
Any ideas?
Old Aug 15, 2016 | 09:03 PM
elduderino200's Avatar
You can check the cable with a multimeter. I wouldn't replace it without checking at LEAST once.
You've checked the belt is on correctly and the alternator is spinning when the car is running?
Old Aug 15, 2016 | 11:11 PM
Voshmag's Avatar
Default Did I buy the right alternator?
Model a11065. 1418410. 12v 150 amp
My car is a 2004 audi a4 quattro avant 3.0l ????
colm92116@yahoo.com
Aug 15, 2016 11:48 PM
gdrenn15
May 29, 2016 06:51 PM
theblackvalley
Aug 26, 2011 01:07 AM
200 QT
Apr 19, 2008 09:39 PM
200 QT
Apr 19, 2008 09:14 PM
