Replacing a brake light in a B5
Old Mar 12, 2014 | 10:15 AM
evenfall's Avatar
Originally Posted by hartsoe1
the B5 has 4 nuts, one at each corner, behind the trunk interior lining. just get that lining out of the way, and you can get to those 4 nuts. then pull the whole light assembly out side the car, not into the trunk. then remove the black backing from the red exterior light and change the bulbs. the B6 only has one nut easily accessible and then the entire light swings out. not sure about a 2001.5
That is exactly what I started doing based on B6 videos I saw before I posted my question. I easily removed 3 out of 4 nuts but the 4th one on the top close to the outside of the car was a pain to get to, seems like there is just not enough space, and I decided to make sure it is even necessary before I proceed.
So from what I understand, there are two ways of doing this: 1)take off the 4 nuts and pull the assembly from the exterior 2) Undo the tabs and pull the bulb cluster inside the trunk. Seems like the tab option would be easier. I didn't get to trying this just yet but I will give it a try this week.
Old Mar 12, 2014 | 03:42 PM
soulstep's Avatar
The tabs literally shouldn't take you longer than 30 seconds. Once you look at it you will realize how simple it is. I just pull off the closest tab, and once that one is free the others come with just a minimal amount of wiggling.
Old Mar 12, 2014 | 05:31 PM
sf_brian's Avatar
Originally Posted by Pbcrazy
Or just not worry about it since you don't use a rear fog light often (since you already have 2 running lights and three brake lights, I don't use it often anyway)
If i cant put in the passenger fog bulb my running lights isnt working at all. Is it because im missing a bulb. Does anybody know why the running lights are not working?
Old Mar 14, 2014 | 12:10 PM
evenfall's Avatar
I was able to successfully change the brake bulb last night. It took a few minutes to work the tabs free but otherwise it was straightforward as you all said. The tabs snapped back easily. Not sure why they just don't give the instructions in the manual. I imagine the headlight assembly is something similar. Thanks for all the help!
Old Mar 14, 2014 | 01:07 PM
MetalMan's Avatar
Headlights are a bit more difficult. You may be able to change the bulb(s) on the driver's side without removing the whole headlight, but you'd either need to remove the headlight or air box assembly on the passenger side to replace it.
Either way it's easier to pull the headlight to replace those bulbs IMO.
karote
Mar 31, 2009 01:39 PM
kriptonik
Jan 15, 2009 09:10 PM
*Shooter*
Apr 24, 2008 02:37 PM
kmm
Feb 4, 2007 01:21 AM
derekgardiner
Apr 19, 2005 01:32 PM
