Replacing rear wheel hub and bearings???
Old Feb 19, 2011 | 01:25 PM
yellow_submarine's Avatar
Not really.... I trust you then.. Bearing it is! Thanks!
Old Feb 21, 2011 | 08:44 AM
Bearing it is! Got both rears done and no more chopper sound wohoo! Thanks guys!
Old Feb 22, 2011 | 05:38 AM
Well i thought it was a job well done however abs light came on after driving about 20-30 miles. Did i ruin the sensor or is there a way to reset that. Whats could be happening now?
Old Feb 22, 2011 | 06:47 AM
mnerobi15's Avatar
I am betting the drive belt is missing some teeth. They cost about $80 in parts to replace.
Old Feb 22, 2011 | 08:23 AM
chocalotstarfish's Avatar
Super Moderator
^^^Spam don't listen
Did you reinstall the ABS and screw it down?
Old Feb 22, 2011 | 08:54 AM
krazzz's Avatar
I hate it when my ABS sensor's drive belt is missing some teeth, almost as much as when I run out of turn signal fluid.
Old Feb 22, 2011 | 09:32 AM
erasmmuss's Avatar
and you allso might need probe to check for the idle fluid level in the oil pan
Old Feb 22, 2011 | 09:56 AM
  #18
normal's Avatar
Originally Posted by yellow_submarine
Well
YS, can you post any thoughts tips suggestions on DIY rear bearings? I have to do that soon too
Old Feb 22, 2011 | 10:59 AM
  #19
Super Moderator
I'll try and find the DIY I used and was super easy. All I can remember was it was a yellow b5 used in the diy pics!
Old Feb 22, 2011 | 11:52 AM
  #20
morpheous's Avatar
oh,you forgot the most important thing,you have to check to see if your missing teeth on the horn belt,god forbid that snaps!
