Rough Shifting/Loss of Power
Old Feb 26, 2015 | 09:52 PM
dgerjets's Avatar
Default Rough Shifting/Loss of Power
96 Audi A4 Quattro 2.8L 5-speed Manual
Odometer 171k
This issue is intermittent, though more frequent in below freezing temps. It has occurred in various temperatures though. When I press the clutch pedal to the floor there is hard jerk as the transmission is taken out of gear, and a clunk when I switch to the next gear or just let off the clutch in neutral. When this is occurring, I often lose power when stopping after pressing the clutch pedal to the floor. Most of the time the car shifts smooth and I experience no loss of power. There is a mild rough idle, fluctuating between 800-1100 RPMs while parked. When it is colder the car idles between 600-900 RPMs. That's all I can think of as far as symptoms.
History of Repairs (That I am aware of):
New thermostat/radiator 160k
Timing belt/water pump 165k
Rear wheel bearings 170k
Oil change every 5k since 160k
Old Feb 26, 2015 | 11:28 PM
elduderino200's Avatar
Throwout bearing? I'm not really a clutch expert so hopefully somebody can confirm or deny.
What I do know though is that once one thing goes bad in there, you may as well do it all. I'm pretty sure 90% of clutch replacement cost is the labor, so once you have the transmission down, you may as well do the whole thing. Sorta like the timing belt/stat/water pump. ...though hopefully i'm wrong in that too.
Dooley12
Feb 23, 2014 04:47 PM
AWD_Addict
May 2, 2011 01:04 AM
rescuer3
Oct 10, 2009 01:22 AM
doomwalrus
May 9, 2009 11:37 AM
stefano5
Jun 19, 2007 09:25 PM
