Running rough
Old Feb 21, 2008 | 11:26 PM
Dave Crall's Avatar
Default Running rough
drove 90 miles today. Parked car for a few hours. Began drive home, while accelerating on the freeway the car began to run rough and the engine light came on. When accelerating it just didn't want to get up and go like usual. When idoling, it was "knocking" and running very rough. It almost felt like it was missing. My car is an 01 1.8T with 111,000. what do you think?
Old Feb 21, 2008 | 11:32 PM
hiwords's Avatar
Default RE: Running rough
did the light come on or did it blink and then stay on? either way get the codes and post it up
Old Feb 21, 2008 | 11:35 PM
Dave Crall's Avatar
thanks for the reply. It's blinking. After letting it sit for a little while, it started fine and idled fine but then began to run rough again after giving it a few rpms.
Old Feb 21, 2008 | 11:37 PM
chaos92287's Avatar
its a misfire, you'll need a new coilpack
Old Feb 21, 2008 | 11:40 PM
Dave Crall's Avatar
think so. thats not too big a deal. Thanks for your feedback. dc
Old Feb 21, 2008 | 11:44 PM
chaos92287's Avatar
when you get the code scanned it will tell you which cylinder is misfiring, and then you just need to replace the corresponding coilpack and it should fix it
Old Feb 22, 2008 | 12:11 AM
Dave Crall's Avatar
Thanks.
Old Feb 22, 2008 | 02:04 AM
Lebe Frei's Avatar
did you check the spark plugs? because i had the same problembecause 2 of my plugs were really bad and cylinders 1 and 2 were misfiring. i replaced them all and it was fine
Old Feb 22, 2008 | 02:16 AM
chaos92287's Avatar
to check the coilpack you just switch two of the coilpacks and if it follows the coil its the coil, if it stays in the same cylinder, its the plug
someroad
Aug 6, 2013 11:53 AM
gardsmc
Dec 31, 2012 09:24 PM
quattroforthewin
Mar 28, 2011 03:46 PM
yesss4
Aug 22, 2009 11:14 PM
bubbasmurf84
Jul 19, 2009 10:01 AM
