Same gear oil for rear diff and transmission?
Old Aug 6, 2012 | 07:52 AM
  #21
vtraudt's Avatar
Originally Posted by bshusted
Don't forget the 16mm triple square "tamper proof" for the drain on the transmission.
Are they NUTS? Temperproof triple square. What do they come up with next?
Thought I got any weird/crooked tool Audi have thrown on the DIY way to annoy us. But here is another one.
FCP has it?
Old Aug 6, 2012 | 07:55 AM
  #22
jonbonesjones's Avatar
Moderator
I don't think FCP has it actually **** that tool. I forgot about it. pain in the *** when you go to do a job and realize you need an allen the size of texas and some shitty triple square the world has never heard of. M16 tmper proof its called i believe.
Transmission Drain Plug Socket Audi A3 A4 A6 VW Golf on eBay!
Old Aug 6, 2012 | 08:02 AM
  #23
vtraudt's Avatar
Default No GL-5 in front/center
For the Allroad, I heed your advise and go with MTL straight!
GL-5 (due to the increased level of additives making it 'tougher') is more agressive. Some GL-5 claim to be 'safe' for yellow metals. Ditto some Gl-4/5 combos. Most agree to stay away from anythign GL-5 for the GL-4 front/center.
GL-5 for rear only.
If it seems that the problem is only during cold weather, I would just run the straight MTL. It is only slightly thinner than the OEM oil and makes it shift like butter. At colder temps, I had difficulty getting into second. Now it's like it "wants" to shift. Just slides in. I'm sold on the MTL.
I'm not sure about the volume required by the allroad, but I would assume it is similar. When filling the transaxle, I found it useful to run a hose up into the engine bay with a funnel.
I'm not sure on the Passat FWD, but the auto A4 will have a separate fill for the center diff (tail housing of the transmission) and the front diff. I'm not sure of the volumes for each.
One last thing to be aware of is type of oil. Some people have reported having transmission trouble when running GL5 oils. The car was designed for GL4 and allegedly the GL5 can be damaging to the yellow metals used for syncros.
Old Aug 6, 2012 | 09:40 AM
  #24
vtraudt's Avatar
Originally Posted by cnigro1279
I just changed both my trans and rear diff last weekend. I got all my redline oils from FCP. Two MT-90 and one MTL in the gearbox and two quarts of 75w-90 in the rear diff. I think it cost around 65 bucks and free shipping.
Only find Redline MTL on FCP.
Can someone link me to MT-90, MT-85 and the GL-5 for the rear diff (redline 75W90 NS GL-5 Gear Oil)?
Old Aug 6, 2012 | 09:52 AM
  #25
CCA4's Avatar
ECS has Redline MTL but from what I've been hearing lately if you order something from them you may or not ever actually get it...
Old Aug 6, 2012 | 10:00 AM
  #26
Moderator
This stuff should be available locally as well. I know a few of the Local shops up here carry Redline products and theres a few with Motul fluids as well.
moneyfresh
Sep 3, 2012 04:53 PM
Donman19
Jul 4, 2011 04:14 AM
damgrmn
Jan 3, 2011 10:54 AM
molon labe
May 3, 2006 07:24 PM
