sea foam on 2.8 30v
Old Aug 28, 2008 | 11:53 AM
nitro_rider2001's Avatar
Default sea foam on 2.8 30v
So i found a couple diy's on the 1.8 but i cant find anything for the 30v. Anyone have any help for me??
Old Aug 28, 2008 | 10:48 PM
ImTheDevil's Avatar
Take off the beauty cover and look at the back of the engine near the top. You'll see a panel in place with a green solenoid and a blue solenoid, and harnesses and lines coming in and out. Right below that, extending out from underneath and pointing rearward, is the suction pump feed hoses. The main one comes straight in, and the secondary enters at an angle from toward the driver's side of the car. They're held on by one-time clamps that have to be cut off and replaced with screw-down hose clamps. Use the primary (coming in straight from directly in front of the firewall) - it should have a lot of suction and will pull the seafoam in quickly.
Old Sep 14, 2008 | 07:25 PM
eurostyleb's Avatar
Pic or diagram?
Old Sep 14, 2008 | 07:35 PM
lumend13's Avatar
peladito y en la boca...lol
Old Sep 14, 2008 | 09:30 PM
30vQuattro's Avatar
mmm, its really hard to miss the feed in line looks like a seven, you cant miss it!
Old Sep 15, 2008 | 03:11 PM
eurostyleb's Avatar
Sorry, I'm new to this engine and I'm trying to learn. There is a hose probably 3/4 inches in diameter that attaches to the crankcase breather hose in the shape of an "L", then there is another hose just underneath that one, same diameter, which appears to attach to the engine in two places then goes to the firewall and the brake booster. Am I looking too close to the surface of the engine? do I need to "get down in there" and find it? or are these the hoses I need? My audi mechanic told me to use the hose coming off the fuel pressure regulator.
Old Sep 25, 2008 | 03:48 PM
Rockpundit's Avatar
When you take off the beauty cover, on the top left corner theres a metal colored object which I think is the fpr. Connected to that is a vacuum hose. Mine was covered in a green cloth like wrap. The hose connects to a y-pipe. The single tube that comes off that should be taken off and used to suck in the seafoam. Be careful with the tubes though, they could be brittle. Mine broke off when I tried to fiddle with them.
Old Sep 25, 2008 | 04:17 PM
onepoint8tee's Avatar
"beauty cover".... that sounds very sexy. got pix?
hartsoe1
Feb 21, 2012 08:25 PM
diggs
B7 Models
Mar 25, 2010 02:01 PM
sydmik08
Jan 11, 2010 02:46 PM
BLK_A4
Dec 20, 2007 10:08 AM
StepUpProductions
Feb 13, 2006 01:29 AM
