Secondary air pump issue and engine smell in cabin
Old Nov 14, 2010 | 03:53 PM
r8ders's Avatar
Default Secondary air pump issue and engine smell in cabin
I keep getting a CEL and it shows insufficient SAP flow on banks 1 and 2. I've replaced all the vacuum hoses and this helped a bit but the CEL light will come back on after a few hundred miles after I reset the light with the same code.
When start first starting the car when its cold, the engine sounds like a jet engine (loud roaring) running for about 30 seconds before the noise dies down. I also get a strong engine smell coming into the interior of the car when sitting at idle at a stop light all the time. I found the source of the smell is is coming from the vacuum regulator/pump area near the where it attaches to the front part of the intake manifold.
Can anyone give me some help here? Thanks in advance
Old Nov 14, 2010 | 10:53 PM
Msnickbroderick's Avatar
Actual WIZARD
Most likely the pump itself is failing
Old May 1, 2017 | 03:24 PM
pdrozdek's Avatar
I have the same problem on my 2001 A6 2.7T. Did you find a solution to the problem? Thank you.
Freddie
May 2, 2017 08:56 AM
gio64
Nov 13, 2010 07:53 AM
rooftoplounge
Oct 19, 2008 03:20 PM
pete7
Jan 23, 2008 12:34 AM
electricute
Jul 3, 2007 03:10 PM
