Intrusive smell in cabin
Old Nov 9, 2010 | 06:35 AM
Freddie's Avatar
Default Intrusive smell in cabin
I need ideas about the following:
When at a standstill or moving under 10 miles/hour, or reversing, there is a strong smell of exhaust fumes coming through the ventilation system. The smell stops when the ventilation is switched off.
This began after a service and mot 2 months ago. The lamba sensor had been replaced. The mechanic advised that it may be old oil burning off after having the cam cover gasket replaced. The smell has not lessened and is very intrusive.
Old May 1, 2017 | 03:21 PM
pdrozdek's Avatar
I have the same problem and I'm looking for help. A6 2001 2.7T. Thank you.
Old May 2, 2017 | 08:56 AM
dave944's Avatar
Check the valve covers near the back for leaks. If they are leaking, oil will drip onto the exhaust manifold and it will get sucked into the cabin air when sitting still. Replacing the valve cover gaskets is not a huge job but you'll need to clean the oil that dripped out the back. A good blast with some "brake clean" will usually wash it off pretty easily if you can get a good shot at it. Clearance is tight back there.
toolagit2qwit
Jan 11, 2014 03:59 PM
gio64
Nov 13, 2010 07:53 AM
bada4s
B7 Models
Aug 26, 2009 12:49 AM
rooftoplounge
Oct 19, 2008 03:20 PM
electricute
Jul 3, 2007 03:10 PM
