Sensor problems
Old May 25, 2016 | 07:08 AM
Stefandelange's Avatar
Default Sensor problems
Hi guys, I'm new but read these ads frequently. I'm having a problem with my Audi B5 1996 2.6 V6. If I start the car it battles to start, then WHEN it starts the car doesn't want to accelerate properly from 800 rpm up to about 1600 rpm. It stutters as if it needs petrol or air. After these revs the car runs very well. Can some-one give me an idea where to look? Thanks,
Old May 25, 2016 | 10:53 AM
A4TurboGuy's Avatar
Does it happen when it's hot, or only when it's cold starting?
Old May 26, 2016 | 08:17 AM
A4TurboGuy's Avatar
Okay: You said it happens whether the engine is hot or cold. How does it idle when you first crank it up? Does it idle smooth, or are there any irregularities?
Old May 29, 2016 | 05:58 PM
ImTheDevil's Avatar
Have you scanned for any stored or pending codes? That's the first place to start.
Old May 30, 2016 | 01:58 AM
Default Car problems
The car battles to start and immediately after it starts you have to crank it a little bit to get it on 800/1000 rpm. After that the car idles perfectly but if you drive with it it seems as if the car doesn't get enough air or gas. The lamda censors was tested and the car was on the computer. The computer says there is nothing wrong with the car. The censors was tested separately and there was also nothing wrong with them. I've also cleaned all the small electrical plugs with electro clean but also didn't make any difference.
Old May 30, 2016 | 06:07 PM
A4TurboGuy's Avatar
Check air and fuel filters. Also check for kinked, crushed or otherwise distorted fuel, air, vacuum lines.
It could also be the fuel pump.
Old Jun 1, 2016 | 09:26 AM
Default MAF problems
I've done all the checks but still has the problem. The MAF sensor is extremely hot after I drove with the car, is that normal? : confused:
Old Jun 2, 2016 | 08:17 AM
A4TurboGuy's Avatar
That doesn't sound normal to me ("extremely hot").
Check your air filter, air box and pre-MAF intake piping again. The MAF should have cool air blowing through it.
If you still can't find any obstructions, start thinking about an electrical issue (test the MAF current, etc.).
redrhino
Oct 26, 2011 03:49 PM
myblueaudia4
Jul 13, 2010 12:40 AM
chaos92287
Sep 16, 2007 08:14 PM
raddox
Dec 20, 2005 07:15 PM
IIrjII
Apr 24, 2004 08:57 AM
