She lives!
Old May 4, 2010 | 09:10 AM
airguard350's Avatar
Tech Guru
Blow it the **** UP.
Old May 4, 2010 | 10:09 PM
kayakman13's Avatar
...yep. Cuz I kayak!
Anyway, besides the helpful suggestion above, can anyone shed ideas? I'm gonna move the #2 coilpack around to see if the misfiring follows, but it seems like all cylinders have carbon fouling. Also, the car fired up after the addition of oil, and a tiny amount at that. I'm getting some puffing of vapor out the exhaust, but I'm assuming thats due to me running VERY VERY rich. So any ideas? I dont want to go out and buy a new coil pack just to find thats not the issue.
So I asked this before: if my fuel pressure regulator vacuum line got a leak, would it cause my car to run rich or lean? Would it be dramatic? I tapped into this line with a no buzz T fitting as per APR's instructions, but I'm trying to rule out all possiblities. I'm hoping my ECU hasn't fucked itself up somehow and that it isn't giving bad info on fuel/air ratios.
Old May 5, 2010 | 06:27 PM
kayakman13's Avatar
Okay, moved the coil pack and still got a cylinder 2 misfire. Also switched the spark plugs and the cylinder two misfire remained. Now I'm at a loss for my next move. Compression test? What could have gone bad? Could my ICM cause one cylinder wire to not be firing?
Old May 5, 2010 | 10:38 PM
DanPHines's Avatar
cylinder 2 misfire = ICM. borrow someones to confirm. im 99% positive that will fix it. your welcome.
Old May 5, 2010 | 11:27 PM
kayakman13's Avatar
Rad! Ok, I'll get on that thanks!
Yentemad
Dec 11, 2007 08:46 PM
NuYorka103185
Jan 5, 2007 07:48 PM
IWantAnA4
Mar 7, 2005 04:29 PM
