Shifting Problems
Old Jan 22, 2015 | 02:54 PM
Zekers's Avatar
Default Shifting Problems
Recently purchased a 1999 A4 Quattro with 159,000. Had a little trouble finding reverse at first, but now I'm having trouble shifting from 1st to 2nd and so on. Is this more likely a clutch issue?
Old Jan 23, 2015 | 09:17 AM
A4TurboGuy's Avatar
How do the clutch pedal and shifter feel when you try to shift?
Any grinding, slipping, burning smell, or just a bad linkage feel?
Try shifting into reverse, then into 1st (while stopped). See what happens.
Old Jan 23, 2015 | 03:43 PM
Zekers's Avatar
Started engine, had trouble shifting into reverse, but no trouble shifting from reverse to 1st. Clutch engages when pedal is about 3/4s up. cannot feel any slipping. Sometimes when I come to a stop it will not shift into 1st. If I switch the engine off, then restart it, I can easily find 1st.
Old Jan 24, 2015 | 03:11 PM
A4TurboGuy's Avatar
I've never messed with our B5s, but that sounds very much like a shifter linkage problem, which (if I'm correct) would be good news, because it would be an adjustment issue and not a "spend money" issue.
This might help: Adjusting shift linkage ... - AudiWorld Forums
Google comes up with a lot of results for this issue.
G/L
Old Jan 25, 2015 | 10:35 AM
Zekers's Avatar
Thanks A4TurboGuy!
Old Jan 26, 2015 | 10:40 AM
A4TurboGuy's Avatar
My pleasure.
G/L w/everything!
teamdaraptor
Nov 11, 2008 02:05 PM
nukemdead
Jun 12, 2006 05:01 AM
1BADS4
Jan 8, 2006 05:41 AM
a6cruiser
May 30, 2005 02:50 AM
skidude
Aug 31, 2004 04:37 PM
