Shop can't Diagnos Problem??
Old Sep 7, 2012 | 05:52 PM
Spondon83's Avatar
Default Shop can't Diagnos Problem??
I took my 1998 A4 (non turbo) to a shop as the check engine light came on and the car stumbles under accelleration...so I figured they can plug into their computer, get the problem codes right...wrong. They could not get their computer and the A4 to "talk" to each other. In fact there was no communication at all.
What the hell is going on? Could there be an issue with the plug that links them together or is there a known problem that would cause this.
The car stumbles when under accelleration, such as passing a car or jumping on the freeway; don't know if its a fuel, electrical, issue but would like to get this fixed.
Old Sep 7, 2012 | 05:55 PM
jonbonesjones's Avatar
Moderator
bad fuse?
is the ABS light on?
Old Sep 7, 2012 | 07:31 PM
Spondon83's Avatar
no blown fuses...and yes the ABS light is on; I understand that to be due to a bad sensor. I'm equally worried that the shop is unable to get their equipment to communicate with the car's computer.
Old Sep 7, 2012 | 07:47 PM
CRAZYHAWK's Avatar
Sometimes, an after market head unit can cause problems with code reading.
Old Sep 7, 2012 | 07:52 PM
FASTER's Avatar
Tech Slut
Pull the abs fuse and try again, after that i'd look at the k-line fuse in the back of the head unit
Old Sep 7, 2012 | 07:54 PM
Moderator
I know advanced hasnt been able to scan my car before with my ABS bad.
Old Sep 30, 2012 | 01:13 PM
Richard C2S's Avatar
I've got a similar problem. ABS light and brake light come on at startup, beeps three times and then continue to flash. At first, we thought it was the left front abs sensor. Now, the Snap-On computer can't communicate with the abs unit. Looks like there is no power to fuses S13 and S18.
Any ideas? Please?
Old Sep 30, 2012 | 04:46 PM
Moderator
ABS module - look for a rebuilt one or get yours rebuilt
Old Oct 29, 2012 | 02:42 PM
Spondon83's Avatar
I'm going to take your advice and get mine rebuilt....I don't have a book but I thought the module was located under the rear seat...but it's not. The only thing under the seat is the Alarm module.
Any idea where the module is?
jonnywill
Mar 12, 2011 04:42 AM
audifan
Jan 21, 2010 10:07 PM
bandaru37
Dealerships
Dec 11, 2008 11:04 AM
sameolpete
Nov 6, 2007 10:52 AM
damir21
Oct 8, 2007 02:29 PM
