Should I be concerned?
Old Jul 16, 2009 | 05:19 PM
Peter1.8t's Avatar
Member
Default Should I be concerned?
Hey guys, I'm new the community here you seem like a helpful bunch of guys so I'd figure I'd ask you guys a question or two before i do anything.
Alright on to the problem..... On my way home today I noticed a "swooshing" sound coming front the driver side of the engine whenever I got on the gas a little hard. At first I thought it might be the AC since it sounded like it was coming from the vent in the cabin but after turning off the AC it still made the sound. I dont have a CEL but if you have any input, it would be greatly appreciated. Thanks
Old Jul 16, 2009 | 05:25 PM
srlito's Avatar
Do you have a boost gauge? If so what was the boost levels under accel. Go to autozone and get your codes checked.
Old Jul 16, 2009 | 06:03 PM
Peter1.8t's Avatar
Member
I do not have a boost gauge, it is on my to do list however. After a quick little drive the CEL is now on so I shall go and get my ECU scanned.
Old Jul 16, 2009 | 07:53 PM
dafrazi's Avatar
Probably a boost leak.
Old Jul 18, 2009 | 06:58 PM
Peter1.8t's Avatar
Member
Scanned my car today and the fault code P0411--Secondary Air Injection System (B2)- Inncorrect Flow, came up any idea's to what this is and/or how to fix it?
Old Jul 18, 2009 | 07:02 PM
srlito's Avatar
I have the same code. When you start your car after its been sitting a while does it sound like a vacuum? its likely that your Secondary Air Pump is dying. Its for emmissions so if you live in a state the doesnt require emmissions i wouldnt worry about it.
Old Jul 18, 2009 | 07:09 PM
Peter1.8t's Avatar
Member
It sounds normal, just idles around 1200rpm for a couple minutes but I assume that is normal. Well it just passed emmissions so I'm good for another 2 years.
Old Jul 18, 2009 | 07:15 PM
srlito's Avatar
mine does the same thing at start up. http://www.ecstuning.com/Audi-B5_A4-...dary_Air_Pump/ is where you can get the pump and the combi valve.
Old Jul 18, 2009 | 07:26 PM
Peter1.8t's Avatar
Member
Awesome thanks for the help
redline380
Sep 5, 2009 10:39 AM
sineo
Aug 19, 2007 02:02 PM
Anos
Jun 4, 2007 09:10 AM
drumdork03
Jan 12, 2007 04:24 PM
mtflycaster
Sep 4, 2004 04:42 AM
