Side Airbag Igniter - passenger side (N200)
Old Oct 24, 2010 | 05:54 PM
vtraudt's Avatar
Default Side Airbag Igniter - passenger side (N200)
The airbag light is on since a while.
VAGcom shows the following error code:
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 M
Component: Airbag 7 Audi 0502
Coding: 00104
Shop #: WSC 06435
VCID: 4081B4DD6AF1
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
32-00 - Resistance too High
The 'measuring block" log reads:
; VCDS Label File
; Audi A4 (8D)
; Component: J234 - Airbag (#15): AIRBAG7
; P/N: 8D0-959-655-???
; includes measuring blocks, coding and adaptation
; This file is part of a redirection package,
; make sure you have all of the following files.
; 8D-15.LBL
; 8D0-959-655-AI7.LBL
; 8D0-959-655-AI8.LBL
; created on 18/Dec/2006 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modification: 30/jun/2008
; requires VCDS 805.0 or newer
; measuring blocks
001,0,Ignitiers I (Front Airbags && Front Belt Tensioners)
001,1,Airbag,Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,2,Airbag,Passenger Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,3,Belt Tensioner,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,4,Belt Tensioner,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,0,Ignitiers II (Rear Belt Tensioners)
002,1,Belt Tensioner,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,2,Belt Tensioner,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,3,Belt Tensioner,Rear Center,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
003,0,Voltage && Seat. Occupation && Belt Inquiry I (Front)
003,1,Voltage Supply,,Specification: Correct
003,2,Occupied Seat,Sensor Pass. Side,Display Range: child/child seat/light adult/heavy adult/occupied/not occupied/not installed
003,3,Belt Inquiry,Front Driver Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
003,4,Belt Inquiry,Front Pass. Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,0,Belt Inquiry II (Rear)
004,1,Belt Inquiry,Rear Driver Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,2,Belt Inquiry,Rear Pass. Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,3,Belt Inquiry,Rear Center,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
005,0,Igniters III (Side Airbags)
005,1,Side Airbag,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
005,2,Side Airbag,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
005,3,Side Airbag,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
005,4,Side Airbag,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
006,0,Seat Occupation (Rear)
006,1,Seat Occupation,Rear Driver Side,Display Range: Too High
006,2,Seat Occupation,Rear Pass. Side,Display Range: Too High
; coding
C00,Airbag 7 (J234) Coding
C01,00?0x: Side Airbags
C02,0 = Front Side Airbags not installed
C03,1 = Front Side Airbags installed
C04,
C05,00x0?: Rear Belt Tensioner
C06,2 = Rear Belt Tensioners not installed
C07,4 = 2 Rear Belt Tensioners installed
C08,6 = 3 Rear Belt Tensioners installed
; adaptation
A001,0,Front Passenger Airbag Deactivation
A001,1,Front Passenger,Airbag
A001,2,Current Status
A001,5,Front Passenger Airbag Deactivation
A001,6,0 = Airbag Enabled (Standard)
A001,7,1 = Airbag Disabled
A001,8,
A001,9,Note: Refer to Service Manual!
When wiggling the middle of the 3 connectors under the passenger seat, I can get one of the values to switch between "too high" and ok (or so).
Measuring Block screen shots:
Old Oct 24, 2010 | 06:01 PM
auditech79's Avatar
You're gonna notice that it only shows up when you have passenger's in the back seat, its a common code to come up on B5's. It usually happens when folks push their legs against the back seat or under it. There really isn't any fix for it.
Old Oct 24, 2010 | 07:29 PM
getinlost's Avatar
I had this pop on me this weekend. Is there a fix so that I can clear the code/light?
vtraudt when you wiggle the wire will it not "stay" wiggled?
auditech79 when I noticed the light I didn't have any passengers at all. I did however dump the clutch a little hard.
Old Oct 24, 2010 | 08:26 PM
auditech79's Avatar
The fault im talking about is temporary, the light should go off when the key is cycled. If your's stays lit all the time you have a faulty airbag.
Old Oct 24, 2010 | 09:09 PM
getinlost's Avatar
Crap.
Old Oct 24, 2010 | 10:09 PM
Andrew149's Avatar
Actually theres a fix for this what is going on is the wire is getting loose so what u do is, put a tie wrap around the airbag connector and than clear the codes and no more codes =]]
i believe the how to is here
http://audidiy.com/
Old Oct 25, 2010 | 07:45 AM
vtraudt's Avatar
More likely, faulty wiring or connector.
Old Oct 25, 2010 | 02:46 PM
getinlost's Avatar
http://audidiy.com/
Would this DIY work? My harness attaches to the seat not the floor.
http://forums.vwvortex.com/zerothread?id=2815467
chawkinson
Apr 28, 2017 07:49 PM
M3Armand
Mar 30, 2013 09:40 AM
mr_indomitable
Apr 23, 2009 11:06 PM
Dallas09
Sep 5, 2007 05:13 PM
