Small issue(starting)
Old Jul 24, 2010 | 11:44 PM
B5 Audi's Avatar
Default Small issue(starting)
K so the car seems to have trouble starting. once on it runs perfect battery level looks good but when starting seems like the battery level drops aand barely gives any power. could it be the battery or waht else could it be cause once on it runs good and every thing idles good ect. just starting seems bad. like if you but the key in and try to turn on right away it wont start you have to put the key in turn forward wait a second then start but its still not a strong start. battery connection maybe?
Old Jul 25, 2010 | 09:03 PM
B5 Audi's Avatar
anyone?
Old Jul 25, 2010 | 09:48 PM
onepoint8tee's Avatar
Are you saying there is a delay between turning the key all the way and when the engine actualy turns over? If so then definitely suspect your ignition switch or starter solenoid (starter.) If you have a 97, the ignition switch is a common failure, and if I remember right- it may be recalled.
It's a super duper idea for you and everyone to put your yr/engine/etc. in their signature. Helps people answer questions more easily.
Old Jul 25, 2010 | 11:04 PM
morpheous's Avatar
yeah,i just put my info in my sig a few days ago,like easier to get questions answered.
Old Jul 25, 2010 | 11:10 PM
joenelson7687's Avatar
a super duper idea...lol
Old Jul 26, 2010 | 12:08 AM
B5 Audi's Avatar
yea its a 97 1.8t sorry had all taht info on there before.
i guess its like a delay i dont know what its called but it just takes longer to start it seems like you gotta hold the key turned for a few "cranks" till it gets enough energy to start up.
Old Jul 26, 2010 | 12:39 AM
So it's a weak crank and turn over? No delay between turning the key and the engine actualy attempting to crank? Could just be an old starter- meaning the solenoid is getting lazy, or a battery on it's way out. How old is the battery? If it is the battery then you'll only have so many weak starts before it finaly quits. How long has it been like this?
Old Jul 26, 2010 | 01:29 AM
B5 Audi's Avatar
Well my dads mechanic suggested a dying battery aswell but ive had the car since november and its always been like this not sure how old the battery is ita came with the car when i got it back in nov. yea its a weak turn on but once its on it runs perfectly fine.
Old Jul 26, 2010 | 01:32 AM
B5 Audi's Avatar
if i can ill try and get a vid tomorrow its a crappy cam but it might help with what im describing
Old Jul 26, 2010 | 01:42 AM
I get what you mean. My 97 was the same way. I think it probably has to do with the starter being 13 years old. The solenoid has coils in at that draw quite a lot of current to make your starter work. Those coils can wear out and draw less current over time which would cause a slower than "normal" crank. Your battery should have a date on it.
