Small issue(starting)
Old Jul 26, 2010 | 01:45 AM
B5 Audi's Avatar
ill take a look tomorrow should i just replace the starter? can i get one over at ECS? or you got a link
edit: just went out battery doesnt have a date on it just says 72 months 12volt also found out it was a walmart battery couldnt that also be part of the problem?
Old Jul 26, 2010 | 02:13 AM
onepoint8tee's Avatar
If it's a walmart everstart battery then there should be a blue sticker (maybe on the side) that has the manufacture date. All batteries have this- unless taken off. I've had a walmart battery for a couple years without any problems. Just because it's a walmart battery doesn't mean it has less cranking amps than any other battery intended for your car. It could still be the battery, though. Rule it out before buying anything. You can have it load tested at Autozone. I'd do that first.
Old Jul 26, 2010 | 12:13 PM
FASTER's Avatar
Tech Slut
I have a starter for sale if your car is a manual. Beats paying a few hundred anywhere else.
Old Jul 26, 2010 | 12:55 PM
B5 Audi's Avatar
Onepoint8tee- i went out this morning to check the battery has a MFD Jan 09 sticker on it.
FasterA4ThanUrs- thanks, ill see if the battery is the problem if not i think ill be picking up the starter from you.
Old Jul 26, 2010 | 01:57 PM
B5 Audi's Avatar
Here's i quick vid i got sorry the radio was on at the beginning lol
crappy quality i know it was a small cannon camera i found here.
should help a little though.
maybe im just crazy and thats normal idk just seems weak to me.
http://www.youtube.com/watch?v=1dmHMggx_1k
Old Jul 26, 2010 | 02:14 PM
Yeah that is very weak. Get your battery tested at autozone. You could also have a weak ground. I'd check the battery to chasis ground. Well, don't just look at it, remove it and clean it and your terminals with a wire brush. While you're at it have your alternator tested as well. It may not be able to fully charge the battery. Autozone can test the alt. or you can unplug your neg. terminal on the bat. and wait about 5 mins. to see if the alternator can keep the engine running.
Old Jul 26, 2010 | 02:15 PM
chocalotstarfish's Avatar
Super Moderator
Why dont u just drive to a autozone/advanced auto/ or similar and have them test the battery real quick and stop guessing?
Old Jul 26, 2010 | 02:26 PM
  #18
Yes
Old Jul 26, 2010 | 02:48 PM
  #19
morpheous's Avatar
I just replaced my battery on my 1997 vw jetta GLS,twice i put in the key,no power at all,took it to autozone and got it tested,wouldn't hold a charge,replaced it and all is fine now. I don't drive it much,being i drive my 2001 A4 everyday ^_^
nelson0639
Dec 8, 2014 04:44 PM
Motomaniac77
Mar 16, 2013 06:46 PM
Dallas09
Feb 14, 2009 05:08 PM
knyks342
May 24, 2008 01:16 AM
china123
Mar 17, 2007 03:43 AM
