Snub mounts
I'm buying snub mounts because my front mount is teared to pieces which explains some of that movement, but the snub mount from APR its about 40 bucks is that just for the front one? or is that come with all 3 or however many there are.
That's just for one (there's only one snub anyhow). Check it out from www.greedspeed.com - it's $12 plus shipping.
yep just teh front, stick with APR or PureMS, i tried the greedspeed (same as 034) and its just too small, the pure ms is bigger and takes up alot of slack and is alot easier to install in my opinion, the APR one is BIG and will probably need some trimming to fit and provide a vibration free enviornemnt. over all teh purems is 40 shipped and APR is 50 shipped so $10 diff. both good.
the snub mount is different than the other 2 engine mounts. for the snub mount, basically what the others said. one advice i have is not to buy engine mounts from ebay because sineo bought them and they are leaking and the customer service sucks. also get rs4 engine mounts because they take care of more of the slack.
i searched this a while back, but i figured i might as well bring it up
isn't the greedspped better for a tip? i had looked around and read that the APR snub would give much more vibrations and would need to be trimmed in order to make it work correctly.
That'd make sense based on what SAudi said. I have also heard that the aftermarket snub gives quite a bit of vibration on the tip cars. If GreedSpeed's mount is smaller, it would have a little play in its mounting that might alleviate some of the vibration.
