So I caved and bought another B5
heres the write up from the inspection on my transmission. typed exactly how it is on here
"VEHICLE DID NOT WANT TO MOVE, CHECK FLUID DOES NOT READ ON DIPSTICK. INSPECT ON LIFT FOUND FLUID LEAKING AT AXLE SEALS, OUTPUT SHAFT SEAL, SIDE COVER PAN GASKET, LEAKING FROM EVERY WEAR. REMOVE PAN INSPECTION FOUND METAL & CLUTCH MATERIAL. FLUID IS BLACK & BURNT"
how in the world do all of those seals give out at one time?
