speaker in door but no wiring going to it?
I had my door apart to screw around with the latch yesterday. When I was getting ready to put my door panel on I noticed there is a speaker there. The wiring goes just a lil ways then ends at an open plug. I never unlplugged it, couldn't find anything to plug it into.
anyone tell me what this is all about......
on a better note passed state inspection today..
Doe the wires look like they are cut or is there a wire connector at the end coming from the speaker? It should plug into the harness in the door. You might want to dig around to see if the other part is hiding - which it very well could be.
Good luck!
Jason
Good luck!
Jason
the wiring goes to a stock plug that is secured to the inside of the panel. I only saw 2 plugs coming into the door 1 for the window motor, 1 for the window switch. When I have the door apart again I will take a closer look to see if they are hiding.
JonnyOctagon
Jul 6, 2008 11:36 PM
