Speedo: incremental ticking instead of smooth sweep
I've searched this forum, and audizine, and I've googled - but found nothing like my speedometer! Rather than a smooth sweeping motion, it ticks incrementally as it goes up (and down) like the second hands on some clocks. The increments are about 2-3 mph.
Additionally, it's sometimes not even close to accurate. I bought the car this past Tuesday. On the 6 hour drive home, it appeared accurate for the first couple hours, then it was registering 10-20 mph slower than actual speed for a couple hours, and then it was accurate again for the last couple hours.
Has anyone had these issues? Suggestions?
Do you have any codes? Do you have a VAG to scan it? If you have the VAG you can do a gauge test to check the gauges in the cluster. Go into module 17 in your VAG ago through the output diagnostics until you find the test for it. ALL the gauges will sweep all the way to the right then back to the left during the check. If the speedometer jumps or weird things when doing the sweep the cluster is more than likely bad. If all is okay, then it could be a speed sensor problem. Another possibility is a broken (Vehicle Speed Sensor) magnetic sensor ring.....
Yeah I can see I'm gonna need a Vag com. When one of my acquaintances heard I got an Audi, he said his vag com would be available for me - but when I messaged him about the speedo issue, he said his won't read cluster communications - said he would need vagtacho.
the full version is nice though.
I had this once, turns out the moronic previous owner was trying to cover up an SRS light and ruined the speedo motor when he pried the needle off. It was doing exactly what yours is but much worse, moving in increments of like 10 km/h and making noises as it moved. You can do an output test via vagcom that will sweep the needles through their whole travel, if it doesn't move smoothly you'll need a new cluster unless you can find someone who can replace just the motor.
Audi Forums Editor
Oct 14, 2013 04:08 PM
