Speedometer not working after engine install
So i just put in my newly rebuilt 1.8t engine and a new clutch.
and the speedo does not want to register, it will not budge.
It is stuck at 0.
There were a couple connections on the transmission that i hooked up, which i assume one of them is the speedometer sensor, but i can't be sure since i'm unable to find a diagram.
Everything works fine, fuel,batter,coolant, and rpm gauges all are accurate except for the speedometer.
Could i have not hooked up the sensor properly or maybe not at all, or maybe it just happened to go bad right after i hooked it back up?
I need help since i'm a bit lost.
The ones i hooked up were right above the driveline on the drivers side of the transmission.
Any help would be greatly appreciated.
It is stuck at 0.
Is that the rpm sensor or the speedometer?
I know that that counts the spins on the trigger wheel, for tdc and all. And makes sure the cranks in alignment.
Ok, so i jiggled the sensor around and unhooked the battery.
The next day i started it and it worked.
i drove 6 miles.
Stopped and when i started driving again it went up to 20 and then dropped and stopped working.
Maybe the sensors bad?
i drove 6 miles.
PFCFRANKIEA4
Aug 13, 2011 02:27 AM
