Speedometer not working after engine install
Old Jan 5, 2012 | 03:56 AM
HulkB5's Avatar
Default Speedometer not working after engine install
So i just put in my newly rebuilt 1.8t engine and a new clutch.
and the speedo does not want to register, it will not budge.
It is stuck at 0.
There were a couple connections on the transmission that i hooked up, which i assume one of them is the speedometer sensor, but i can't be sure since i'm unable to find a diagram.
Everything works fine, fuel,batter,coolant, and rpm gauges all are accurate except for the speedometer.
Could i have not hooked up the sensor properly or maybe not at all, or maybe it just happened to go bad right after i hooked it back up?
I need help since i'm a bit lost.
The ones i hooked up were right above the driveline on the drivers side of the transmission.
Any help would be greatly appreciated.
Old Jan 5, 2012 | 09:42 AM
jonbonesjones's Avatar
Moderator
Old Jan 5, 2012 | 12:25 PM
HulkB5's Avatar
Is that the rpm sensor or the speedometer?
I know that that counts the spins on the trigger wheel, for tdc and all. And makes sure the cranks in alignment.
Old Jan 5, 2012 | 07:37 PM
HulkB5's Avatar
Ok, so i jiggled the sensor around and unhooked the battery.
The next day i started it and it worked.
i drove 6 miles.
Stopped and when i started driving again it went up to 20 and then dropped and stopped working.
Maybe the sensors bad?
Old Jan 6, 2012 | 11:40 AM
Mike-2ptzero's Avatar
Most likely a VSS that is on the transmission or a bad sensor ring that is behind the cover behind that axle flange.
AcousticNRG
May 26, 2014 02:09 PM
jimmyjames72
Aug 9, 2013 01:49 PM
PFCFRANKIEA4
Aug 13, 2011 02:27 AM
freeriderocks
Sep 6, 2007 02:34 PM
cmk87
Jun 11, 2007 10:46 AM
