speedometer and odometer not working please help.....
Old Jul 7, 2011 | 10:25 AM
MagA4's Avatar
It's not the VSS. I changed mine and there was no improvement. I never thought of the battery though although I doubt it is. My battery is on its way out. I will change the battery shortly and give some feedback.
Old Aug 11, 2011 | 05:59 PM
Mattt6511's Avatar
I hate to bring back a month old post but my 96 a4 has the same problem. The speedometer and tachometer don't work. The odometer and everything else works fine though. My biggest problem is my car only has 118k miles and all the used clusters for 96 have 160k+ is there a instrument repair place you would all reccomend that I can send my cluster out to be repaired or something?? Thanks!
Old Aug 12, 2011 | 08:23 AM
audinoob88's Avatar
Im going to order a cluster from ebay or out of a junkuyard, but I have a question. Does the cluster have to be programmed? Im not really worried about mileage I just want to see if it fixes my issue. I just don't want lights flashing and things not working properly.
Old Aug 12, 2011 | 10:43 AM
Mattt6511's Avatar
No I'm amost positive they don't have to be programmed I think I'm going to send mine off to some place in Tampa to have it rebuilt hopefully they are able to fix it!!!!
Old Aug 12, 2011 | 10:46 AM
mekeraudi's Avatar
Default speedometer problems here too, link
I have speedometer problems on my 99 a4 also.
Try out the following link or even search the forums at audi zine.
Good luck and let me know what you find out.
Speedometer & Vehicle Speed Sensor problems
Old Aug 13, 2011 | 02:27 AM
audinoob88's Avatar
So i installed a new VSS today and still no go. Im wondering if my audi has the broken magnet ring. My cluster worked yesterday from my house to work. It never dropped out, but when i shut the car off it started bouncing at 0. It hasn't worked since then. Im thinking its cluster bc the needle bounces at 0 instead of just laying there. I don't have a vag computer and no one in town does so i can't perform a cluster test. Any ideas or suggestions?
njsully
Jul 3, 2024 02:08 PM
AcousticNRG
May 26, 2014 02:09 PM
Crookedtoad
Dec 23, 2013 03:18 PM
freeriderocks
Sep 6, 2007 02:34 PM
SteveZ
Aug 23, 2006 01:39 AM
