Speedtuning Ecu upgrade questions!
^sounds like a problem...lol
the autometer I currently have is a 30/30 and the VDO I am gettin is a 25/30...20 is definately a littly low
cincy, aren't you building your 1.8 to a 2.0, or at least going for some new internals and such?...think I remeber you mentioning something about your car in pieces and an eventual t3/t4 maybe?...could be mistaken tho
Yes im currently building a 2.0. The plans were a t3t4 50trim before the build, but now that i will have a built motor i have decided to go with a gt3082r .63. Its the same turbin as a gt3071/76 and compressor as a gt35r and gt4082r. Should make 450whp on pump easy and close to 500whp with w/m injection when all is said and done. Needless to say i will need ATLEAST 35psi gauge if not 40
oh nice...so it's all built and back in the car?...or is the TT down?
sounds like it is gunna be a monster!...are you fronttrack or quattro?....
35 psi will be nuts!...are you building a sleeper or are you guna be tracking it?
I don't go into the TT forum usually...do you have a build thread over there?
The car is still apart. I have a fwd car. Will be somewhat stockish but a drop and wheels. Its being built for a highway monster and my enjoyment. There is a build up thread in the TT section but its dead since im having problems with my "builder".
Goal is 2600-2650lbs and 450whp on pump. Should make a 11sec car on street tires.
that'll be nuts!
I could see you on the freeway downshifting into 3rd and spinnin the tires a bit...lol
11 sec. street car is prolly too much for me, although I can't say that every once and a while I don't wish I had that kind of power
you're gunna have to launch outa second...lol
good stuff man, hope you figure everything out with the builder...bet you miss havin the TT as your DD [&o]
man that sux!...do you still sit in the shell and make racecar noises?...lol
well, hopefully your car gets back together soon enough....
so is the motor comletely back together, or is it still in pieces?....a built 2.0 with a stock turbo and the diode mod would be really funny
you think you may go standalone?
what cc file are you guna run with? the ctapp 630?
