Squeak,Squeak....help...goin nuts
Old Jun 3, 2009 | 11:45 AM
ron86toy's Avatar
Default Squeak,Squeak....help...goin nuts
This is the wife car...'98 2.8 quattro....been getting a weird squeak in the right rear.....I recently changed the caliper slide pins...sway bar end links(was told both could be the culprit).It does not do this all the time.I have pushed on that corner when parked and produce the sound.I am down to replacing the struts....before I spend the cash on those,could there be something else I am missing?????
Old Jun 3, 2009 | 06:37 PM
bkraska's Avatar
Bushings in the rear control arms could cause this noise.
Old Jun 4, 2009 | 12:52 PM
acetrebo's Avatar
More likely the control arms, than the struts.
Old Jun 4, 2009 | 02:35 PM
Interceptor's Avatar
Control arm bushings. Mine did the same exact thing and I sprayed them with WD40. It will crop back up when it's dry and warm out after a bit as well. Blauparts has a whole rear end bushing kit if needed in the future .
Old Jun 4, 2009 | 02:36 PM
Lol, hey I'm over in Harrison btw .
Old Jun 4, 2009 | 03:40 PM
ron86toy's Avatar
I will give the WD a try for now...how hard are the bushings to do?????driveway job???
I am between Gladwin and Beaverton on 18...she goes to Mid for school.
Her car
We are most recognized around here by the yota
Old Jun 4, 2009 | 05:14 PM
I believe you need to have a shop press them in if you order the bushing(s) seperate or you can get a new rear control arm with the bushings $$$$$.
If you opt for the control arm you can get it done in your drive if you can turn a wrench. Problem is trying to find that bugger that is causing the squeak.
Nice truck. My old lady works at Mid . Good ole Gladwin. Better than Harrison these days.
marcb0127t
Feb 7, 2009 07:55 PM
incrementalg
Dec 20, 2008 12:07 PM
audi_n00b
Oct 31, 2008 07:46 PM
Trey25
Jul 28, 2006 01:22 PM
klb3284
Mar 29, 2006 10:16 PM
