start up problem
Old Aug 22, 2008 | 06:20 PM
Tweaked's Avatar
Before cranking, try cycling the key on and off a couple times to run the fuel pump. If it fires up quickly after doing this, you may have a fuel pressure or FPR issue.
Old Aug 22, 2008 | 06:52 PM
CL AUDI EOUS's Avatar
Sure did! Could a dv be the problem at all? Cause I have chipped my car, but have not upgraded that yet...
Old Aug 22, 2008 | 06:53 PM
okay thanks Tweaked!
Old Aug 22, 2008 | 09:14 PM
Also... I dunno if this will help at all, I went on a couple of vacations this summer and the car just sat for about five to ten days and both times when I came back from the vacations and started the car, there were no problems at all...
Old Aug 22, 2008 | 10:08 PM
Tweaked's Avatar
Does it do it only on hot start-ups?
Old Aug 22, 2008 | 10:14 PM
ghost6303's Avatar
the DV would only cause you to not boost as high as you could if you had a DV that could hold the pressure.
i agree with the fuel idea. you might want to consider changing your fuel filter. i did mine and it was fairly clogged after 10 years of service.
costs about 25 bucks in parts, make sure you order new washers for the banjo fittings, there are 2 on each line, 4 all together. the 'in' and the 'out' are different sizes. it takes an hour or two to change because its kind of a pain to get to. there are write ups on how to do this. its a cheap fix to try and even if its not the problem its a good idea to do anyway.
Old Aug 23, 2008 | 07:37 PM
What do you mean by hot start up? Arizona is always hot... Do you mean like temp wise or after the car has been running awhile? I guess it doesn't matter either way cause it does it every start up unless I restart within like the minute.
Mattman26
B8 Models
Jul 29, 2014 07:43 PM
aziz
S4
Jul 6, 2013 03:47 PM
douche'
Nov 15, 2012 07:22 AM
N1a6Germ
Oct 6, 2010 12:51 AM
fatal02
Jun 21, 2006 07:56 PM
