starting problems...
Old Feb 28, 2011 | 06:54 AM
SteveH's Avatar
Default starting problems...
searched the forum without success...
Got in my 99.5 A4 (1.8) the other morning, turned the key and had a rough start. It turned over for about a second, then died. Tried starting again, and it just whined-just the starter sound, with no firing up.
Battery is good; it's getting plenty of juice when the key is turned. Just seems like the plugs aren't firing.
Is this the coil pack(s)? I don't have any software to diagnose the problem, so if it is, I won't be able to see if it's one, two or more of them.
Thanks in advance for any thoughts.
Old Feb 28, 2011 | 10:29 AM
morpheous's Avatar
seems like an ignition issue,either it's a connection with your ignition or ignition control module,coil packs wouldn't cause your car to not start,when they go bad,the only thing they will do is cause one of your 4 cylinders to misfire.
Look at your ignition control module and the connection between your ignition.
Old Feb 28, 2011 | 12:09 PM
JoBuNY's Avatar
Did you actually test the battery to make sure it was good?
To fully test you should do 2 things:
1. Put a meter on it and make sure you are close to 12 v when car is off
2. Leave the meter on the battery and have somebody turn the car on, make sure the volts don't bottom out. My friend had a battery he swore was good, but the car wouldn't start. When I kept the meter on and he turned the key the volts dropped to like 4 and the car never started. Put in a new battery and good to go
Just a suggestion
Smokin Tubes
Feb 5, 2012 10:11 AM
joe4123
Sep 16, 2009 11:17 PM
joe4123
Jun 19, 2009 08:05 PM
james0013
Sep 2, 2008 11:22 AM
Limmy711
Sep 15, 2005 02:11 AM
