Stock clutch potential
Old Sep 8, 2008 | 05:52 PM
  #21
M3Armand's Avatar
Originally Posted by Mike@DTH
Not bad, now try that on a surface that isn't covered in dust. A shop floor isn't exactly designed to have good traction.
1) I love the vid!
2) +1 on Mike's comments above and that you should try it with Z rated high performance tires on a nice hot asphalt.
Yes but once the car tries to hook the clutch will end up slipping since it is the weak link in the driveline. I have been drag racing A4's for 8 years with everything from chip to 600whp. My stock clutch held up just fine with just a standard K03 chip, but once we pushed the K03 to 250chp with a custom GIAC tune the stock clutch would not hold a hard launch. With an upgraded clutch I was able to run 14.29 at 97 mph.
Say Mike, are you able to chirp Z rated tires on asphalt with a chip alone? I.e. - my wife has the APR "93 octane" chip that gives roughly 160 rwhp per my Gtech pro. I'd post a pic, but I can't see an "attachments" section anywhere. So, I am wondering if something was wrong with her clutch - i.e. - it was a bad install.
Old Sep 9, 2008 | 12:05 PM
  #22
Mike-2ptzero's Avatar
Originally Posted by M3Armand
1) I love the vid!
rwhp? What kind of car does she have that is rwd and runs a APR chip?
It isn't easy to chirp the tires on a A4 1.8t quattro with the K03 since it doesn't really make all that much hp/tq at 4k-4500 which is the sweet spot for launching a K03 setup. Now I guess you could chirp or spin the tires if you really wanted to launch at a much higher rpm.
Old Sep 9, 2008 | 01:36 PM
  #23
M3Armand's Avatar
rwhp = rear wheel hp
and you are right... In this case, I meant AWHP!
Even when launching at higher rpms, I still can't spin the tires.. clutch just slips..
Old Sep 9, 2008 | 02:25 PM
  #24
Have you tried running the tires at 45+psi? You might just need a better clutch.
ricky0323
Nov 13, 2008 09:56 PM
01A4B5
Apr 19, 2008 03:00 PM
MaXo
Feb 9, 2008 01:29 PM
Dstranks
Aug 28, 2005 04:16 AM
MauricerS4
Aug 12, 2005 03:14 PM
