Stripped fill plug
Old Feb 18, 2012 | 05:53 AM
ckrummy's Avatar
Default Stripped fill plug
So I just finished replacing my rear axle seals and changing the fluid, I get it put all back together and fill up the differential and it turns out the fill plug hole is stripped, the plug just never tightened up, it looks like the previous owner just glued it in. what is my best permanent fix for this that's not going to get aluminum shaving in my diff.
Old Feb 18, 2012 | 10:42 AM
M5S5's Avatar
Tech Certified
I think a helicoil would be the best repair for you. You would have to find you thread pitch & diameter & look around at auto part stores for the size you need.
If you want to do a temporary fix i would clean all the old silicone off , wipe clean the threaded area with brake clean & a rag & re silicone the plug back in. Let it dry overnite & you should be good.
Old Feb 18, 2012 | 12:13 PM
bshusted's Avatar
In order to do a helicoil you'll have to drill and tap the diff housing to a larger size, which will introduce shavings into the diff. Even so, this is probably the most permanent solution other than pulling a used diff out of the junkyard.
There really shouldn't be any strain on the plug, so RTV should be fine to hold the plug in. For peace of mind, I don't think I would run it this way for very long.
Old Feb 18, 2012 | 01:37 PM
ckrummy's Avatar
I found some permatex thread fixing compound at the parts store so i'm going to give that a shot and see. I wish i could just go to the junk yard but none of them around here have Audi's of any kind.
Old Feb 18, 2012 | 03:51 PM
turbo kraut's Avatar
Tech Guru
and if you do thread the diff, use petrolium jelly to help with the shavings
Old Feb 18, 2012 | 06:15 PM
airguard350's Avatar
Tech Guru
What Jeff and husted said. Normally I'd suggest JB but it's a fill plug so that's a bad idea. If it's the threads on the plug itself, you can try re-cutting the threads and see if that helps.
a2thy
Feb 4, 2010 12:15 AM
hottubbrad
Dec 16, 2009 11:24 PM
jchaffee1
Oct 27, 2008 09:42 PM
jonny29
Feb 21, 2007 03:01 AM
werkwitdis
Jun 4, 2006 02:07 AM
