Successful spark plug gap experiment.
Old May 7, 2010 | 02:51 PM
A4 2000's Avatar
Originally Posted by kayakman13
The reason damage COULD occur is that in some engines, if you over gap you could have the piston hit the spark plug.
Ha, ha. No. When a gap is too big, the ignition system can't provide enough voltage, which causes misfires. Even more with high compression or f/i applications. When there's a dense a/f mixture in the combustion chamber, you need a small gap to ensure that the spark can cut through this mixture. This is why I was misfiring before and the fact that our coil packs are a little on the weak side.
Old May 7, 2010 | 04:25 PM
dragonrage's Avatar
Right. The spark is weaker with longer gaps. You want the spark to be just strong enough so that it burns reliably, with as wide a gap as possible so as to have the most surface area to ignite the fuel mixture with. You need to find that happy medium.
Old May 8, 2010 | 09:35 PM
turtleboy's Avatar
Spark plugs are not going to hit the pistons if you gap them wide. I don't know where you heard that.
This. ^^
Generally, when you up the pressures inside the combustion chamber (more boost or higher compression ratio) you need to reduce the gap.
Old May 8, 2010 | 11:33 PM
Midniteoyl's Avatar
hey Hey! Give that man a ceegar...
Other than the gap having to be with in range of the actual power available (ie: coils) to actually 'spark' over, the smaller gap with run better at higher rpms while the larger gap will run smoother at idle. The factory setting is a compromise between the two.
Old May 9, 2010 | 11:55 AM
kayakman13's Avatar
This. ^^
I mostly said it as a joke lol.
Old May 9, 2010 | 09:45 PM
A4 2000's Avatar
Originally Posted by Midniteoyl
...the smaller gap with run better at higher rpms while the larger gap will run smoother at idle. The factory setting is a compromise between the two.
So, if I were to get stiffer valve springs and set the ecu at a higher red-line, do you think a .025" gap would be a good setting for that? Just curious.
Old May 10, 2010 | 12:54 AM
Midniteoyl's Avatar
Prolly... Though I'm more inclined in improving the spark through hotter coils, better wires, etc, than I am for reducing the gap. A bigger gap 'unshrouds' the spark more.
Old May 10, 2010 | 03:13 AM
  #18
A4 2000's Avatar
What sucks is that you can't find aftermarket stuff like that. Unless I'm totally unaware that there really is.
Pilipenko
Nov 28, 2011 10:06 AM
ee99ee
Oct 12, 2011 12:28 PM
Anos
Jun 9, 2007 10:02 PM
germancarmaniac
Jan 3, 2006 01:33 PM
rexbombay6
Nov 29, 2005 06:48 PM
