suction pump issue
Old Jan 26, 2010 | 02:00 AM
A4 2000's Avatar
Default suction pump issue
I have a problem where the widest funnel-like part tends to separate too easily from the other side. All I have to do is barely move it and it separates or after a day or two of vibrations from driving. I have it wrapped up a bunch of times with electrical tape at the moment as a temporary fix, but I want to fix it the right way. Is the only way to fix this is to get a new one or am I supposed to make it snap on a certain way? I didn't realize how important this part is until it separated one day and the low vacuum made the car turn off when I came to a stop.
Old Jan 26, 2010 | 01:48 PM
ImTheDevil's Avatar
Honestly i would replace it. The hoses just go onto it and have clamps secoring them. Chances are that work in the past ended up damaging it (if it doesn't have one-time clamps on it, it's been messed with). Throw a new one on and be done with it.
Old Jan 26, 2010 | 03:37 PM
collins's Avatar
yeah this can make your brakes go out as well. i had mine break when i first got my car and lost all power to the breaks while driving, you dont want to be in that situation on the highway or something.
Old Jan 27, 2010 | 02:47 AM
A4 2000's Avatar
What I don't understand is that where it separates, it doesn't look broken at all. I guess it would be a good idea to just get a new one though. I was looking on ecs and saw that there are two to choose from. Does anyone know why the revised one is almost twice the price of the other one?
Here they are:
http://www.ecstuning.com/Audi-B5_A4-...Intake/ES3223/
http://www.ecstuning.com/Audi-B5_A4-...take/ES252639/
Old Jan 27, 2010 | 10:38 AM
collins's Avatar
one is audi/vw and is why its so much more, the other is just an oe supplier. i got the cheaper one and it works fine.
Old Jan 27, 2010 | 03:33 PM
bbboy's Avatar
Member
I put epoxy on mine, let it cure, then wrapped aluminum foil tape (Home Depot) around. Mine had vacuum leak around the whole perimeter where yours have. So, after replacing few other vacuum lines, I am now at -20" vacuum when idle and -23" when coasting in gear with gas off. I guess that's what it is supposed to be?
Old Jan 28, 2010 | 12:08 AM
A4 2000's Avatar
So is this a common problem then? Why do these things come apart? I don't want to pay for another one and then have it pop off again. Maybe I should just seal it up and then tape it up real tight?
Old Jan 28, 2010 | 12:33 AM
bbboy's Avatar
Member
It's up to you. I am waiting for few other things to order and then I will order the pump as well. So far, it's been 6 months that I did my epoxy + aluminum tape trick and still works fine. No leaks.
Old Jan 28, 2010 | 01:06 AM
Interceptor's Avatar
I should be replacing mine as well this weekend due to constriction problems. I also believe and this is just me, these need to be checked on or replaced when doing normal tune up schedules.
Old Jan 28, 2010 | 01:42 AM
A4 2000's Avatar
This thing should have just been made as one piece. I'm going to write my congressman.
