Sudden oil leak from front of 2.8 engine
Old Mar 12, 2014 | 04:07 PM
sweenepj's Avatar
Default Sudden oil leak from front of 2.8 engine
I have a 99.5 with the 2.8l engine. After letting it sit a couple of days, I came out and it had dumped maybe 1/4 to 1/2 quart of oil on the floor of my garage. I did some initial searching and replaced the oil cooler o-ring since that seems to be a common source of leaks. I ran the car for a bit, and the leak persists. The oil is running down the front of the engine, from above the the lower oil pan seal so that's not the source.
I don't think it's the valve cover gaskets as they were replaced about 10k miles ago with the timing belt. From the top, everything looks dry.
Any ideas what to check next? I can't see much else without removing the radiator. I'm willing to do that, but if it's just going to narrow it down to one of a couple major repairs then I might just take it to a shop.
Old Mar 12, 2014 | 09:14 PM
sweenepj's Avatar
Here's a little more info--the car does not seem to drip any oil while it's running, but when I turn it off it drips heavily down from the front of the engine.
Old Mar 20, 2014 | 10:39 PM
jeckel20003's Avatar
Possible places it could leak oil on the front of the engine:
Camshaft seals
Camshaft tensioner gasket and halfmoon seal
Oil cooler
Oil temperature sensor
Crankshaft seal
caozam
Oct 15, 2014 01:54 PM
generic
Apr 21, 2014 05:29 PM
highrpm
Nov 20, 2012 07:36 AM
matthewliamjackson
Jan 5, 2008 03:33 AM
sam.T.
Feb 12, 2007 10:38 AM
