2003 1.8T Oil Leak Front of Engine
Old Nov 14, 2012 | 08:44 PM
highrpm's Avatar
Default 2003 1.8T Oil Leak Front of Engine
I own a 2003 A4 1.8T. Recently there have been several drops of oil under the front of the car. The underside of the car is wet but not much oil in the engine compartment.
I took a peek under the timing belt cover. There is oil everywhere in there.
What are the common leak points on this engine that would cause so much oil to leak especially under the timing belt? Crank seal? Any other sensors under the belt cover maybe? The Cam sensor maybe?
There is enough oil that I can't believe this would be a valve cover leak.
Old Nov 16, 2012 | 03:01 PM
pa4ul's Avatar
its probably the cam tensioner gasket.
Old Nov 16, 2012 | 03:21 PM
ECS Tuning's Avatar
Sponsor
^^ Could be. Cam seals, cam chain tensioner gaskets, crank seal, valve cover gasket are all common places for oil to leak from on 1.8T's
Jason
Old Nov 20, 2012 | 12:25 AM
sick_vdub's Avatar
Well the tensioner is in the back of the motor, so it wouldn't leak into the timing belt cover... Cam seal or the valve coer gasket are tho most likely things...
Old Nov 20, 2012 | 07:36 AM
highrpm's Avatar
Thanks for the replies.
caozam
Oct 15, 2014 01:54 PM
generic
Apr 21, 2014 05:29 PM
sweenepj
Mar 20, 2014 10:39 PM
SkipsA6
May 27, 2011 09:43 PM
matthewliamjackson
Jan 5, 2008 03:33 AM
