Surging and random poor gear changing
Old Nov 26, 2010 | 02:41 PM
VFX's Avatar
VFX
Default Surging and random poor gear changing
I recently bought a 1996 Audi A4 2.6l Auto, which when it gets up to normal temp, it has a slight miss or surge while.
When cold it was fine, it was only once it warmed up the issue occurred. Travelling at 100km/70mph it also seemed fine, but lower speeds and going uphill the miss/surge is pretty regular.
The car starts and idles fine also.
I also got a random poor gear change occasionally.
Unfortunately the problem is getting worse as the days go on and the miss/surge is now happening even when the car is cold and the poor gear changes are more frequent.
I've checked the leads and they are OK, changed the coil pack and the ICU, but these haven’t made any difference.
No codes other than In2 showing
Any suggestions?
Old Nov 26, 2010 | 03:53 PM
Andrew149's Avatar
Any suggestions?
if you bought anything but oem coil packs you fail oem only or the issue will always be there
http://www.ecstuning.com/Audi-B5_A4-...ion/Coil_Pack/
you should of bought one of those so
now lets say you did that, it could be that the rubber under the hood from the years have gone bad so you have a leak and now u have a vacumm leak thats making the car hicup so check for any leaks cheack all fluids make sure to use good quailty products on this car check spark plugs to see if the car is running rich or lean
Old Nov 26, 2010 | 08:21 PM
Tweaked's Avatar
Load signal comes from the MAF on VAG products. Start by cleaning and inspecting the MAF and see if the issue persists. My first thought was a bad torque converter, but a code is almost always stored when they fail or the TCC sticks.
If it's missing at idle as well, you have an engine issue. Start by checking the plugs if you haven't already. If it only misses while under load, it could be something more like the MAF or even a transmission issue. It's hard to tell by your description.
Last... what is In2?
Old Nov 27, 2010 | 10:53 AM
dragonrage's Avatar
Vacuum leak
Coolant temp sensor
steve.mason
Apr 28, 2013 02:57 PM
harmeetsingh
Oct 12, 2010 03:33 PM
sollyd25
Sep 2, 2009 08:28 AM
BoognishBoogie
Jul 26, 2009 03:41 PM
Blur_blah
May 28, 2009 09:32 AM
