Suspension Banging from the back on hotter temperautres
Old Jan 24, 2011 | 11:18 PM
exequiel3k's Avatar
Default Suspension Banging from the back on hotter temperautres
Well, it's that time again
I've had this banging sound coming from the back of my car when passing over bigger potholes.
Odd thing is that when the temperature is pretty cold outside (ie -15degrees Celsius or less), it will most likely Not produce this banging sound (sorta like my spare tire is loose).
I though it was my trunk not locking itself properly and being loose, but it isn't. I've checked for any play in my spare tire or items in the trunk , but nothing is budging.
I don't know where the Banging noise is coming from (except I know its from the back ). My shocks and arms have been replaced, diagnosed with rear-left tie-rod being due, but not urgent.
Any suggestions??
Old Jan 26, 2011 | 10:46 AM
exequiel3k's Avatar
no one has anything to suggest?
Old Jan 28, 2011 | 10:49 AM
Emilgevor's Avatar
control arms could be the problem.
Also check trunk for loose items. Sound travels and it could be just as simple as loose item around your trunk.
Old Jan 29, 2011 | 01:39 AM
hiwords's Avatar
rock the exhaust by putting your foot on the exhaust tip. push it towards the driver's side
Old Jan 31, 2011 | 06:38 PM
powersmokin's Avatar
My car was doing this and it turned out to be the nut and bolt at the to top of the shock that holds the shock to the strut housing it was loose i would check that and see if it goes away.
Old Jan 31, 2011 | 09:40 PM
exequiel3k's Avatar
oki, thx
I'll check them all out..!
Note: My exhaust does have some play (left-to-right),
Isn't it normal that It moves a bit, or is it suppose to stay Firm??
Old Jan 31, 2011 | 10:08 PM
Emilgevor's Avatar
it supposed to move a lil bit because you have rubber hangers but not much
Old Feb 7, 2011 | 10:25 AM
exequiel3k's Avatar
Problem solved;
the rear banging was actually my rear-windshield that was loose. It could be moved just by pushing with my fingers..!
Anyways, now I can drive over potholes in peace (even though I still try to avoid them XD).
erm9509
Apr 4, 2008 10:57 PM
m_b
Aug 13, 2007 12:34 PM
eliTTe
Mar 18, 2007 11:17 PM
