temperature light Flashing!!!
Old Oct 28, 2008 | 07:33 PM
audikiller09's Avatar
Default temperature light Flashing!!!
i was doing doughnuts in the parkinglot today and i noticed my temperature light flashing, but all the temperatures were normal.. I opened the hood and the only thing wrong was that i was kinda low on antifreeze (below minium mark). Could this be the issue?
Old Oct 28, 2008 | 07:53 PM
Bogie's Avatar
yup. if your antifreeze level is low, it could be that you got a pocket of very hot air by the temp sensor, which caused it to go off. you should check your radiator, o-rings, and the ends of all your hose connections for leaks or pink crusty residue.
Old Oct 28, 2008 | 08:03 PM
ghost6303's Avatar
it could also be your coolant level sensor going off. theres a plug on the bottom of the tank when the level gets too low (or when i forget to plug it back in after moving the tank) the light goes off.
Old Oct 28, 2008 | 09:33 PM
theres no pink residew so theres no leak. It flashes for 30 seconds then when i keep the car still it goes away
Old Oct 28, 2008 | 10:25 PM
ghost6303's Avatar
how about fill up the tank and see if it goes away?
delpero
Apr 29, 2015 05:19 PM
plumbous
Nov 20, 2007 10:12 PM
blanthony
Mar 25, 2006 01:18 PM
