Thermostat replacement
Old Jul 13, 2011 | 11:33 PM
A4 2000's Avatar
Default Thermostat replacement
This looks like a pretty easy swap, but from looking at it, I have one question. That bar that runs across in front of one of the bolts seems to be in the way even if I were to use an extension. Before I go at it, am I going to need to remove that bar first or would the socket be able to attach to the bolt ok? If I do, nothing will move or fall on my face right?? Lol. Thanks. Here's a pic.
Old Jul 14, 2011 | 09:13 AM
CCA4's Avatar
Nah you're ok. That bar doesn't hold anything up, its just bracing between the motor mount and snub cage. Carry on!
Old Jul 24, 2011 | 04:27 AM
A4 2000's Avatar
Ok, I put in the new thermostat today and a new coolant reservoir. I got the new thermostat rated at 180 deg. F. The stock one is set at 195 right? I let the car warm up and I drove around for a little bit to make sure there were no leaks and was curious to find out where the needle would sit now. I noticed that the needle only went down maybe barely a hair less than where it used to sit at. Shouldn't 15 deg. make a bigger difference than that?
Old Jul 24, 2011 | 08:38 AM
ImTheDevil's Avatar
If you measured coolant temp with a thermocouple you'd probably see a difference. Factory gauges are usually a rough estimate more than a precise reading, so a relatively small difference in operating temp is unlikely to register on the stock temp gauge.
Old Jul 24, 2011 | 11:08 PM
A4 2000's Avatar
Oh ok. Thanks. It's just that every car I've had, the needle always sat a little below the half way mark. This car sits a sliver above the half way mark. Is that what everyone else's A4 does?
Old Jul 25, 2011 | 01:58 AM
A4 2000's Avatar
Here's a pic.
Old Jul 25, 2011 | 11:55 AM
jdahlen24's Avatar
Looks ok to me. My needle sits dead center on the white line, but my wife's B6 sits right where yours does.
I would be more concerned where the needle on your gas guage is right now.
Old Jul 25, 2011 | 02:51 PM
Mad Cow's Avatar
BEEEEP. Goddammit car why are you beeping at me I know the tank's almost empty.
Happens damn near ever week.
Gary Knox
Jan 20, 2014 09:07 PM
altonachrome
Dec 13, 2009 10:15 PM
ecriswell
Sep 2, 2006 11:01 PM
ChrisB
Feb 17, 2005 07:02 PM
A4izzy
Mar 9, 2004 05:29 PM
