Third brake light cover . . .
Old Jan 25, 2016 | 05:20 PM
eelpie's Avatar
Default Third brake light cover . . .
Today I discovered I had two of the four bulbs out in my third (center) brake light and I want to get them replaced. The car is an '01, but I believe the cover comes off essentially the same way on all the B5 sedans.
My question: are there pressure points on the cover that make the release easier, or is it a matter of brute strength to yank the thing out?
I am not as limber as I once was, go getting a grip for brute strength is a bit of a challenge . . .
Thanks.
Old Jan 25, 2016 | 06:16 PM
elduderino200's Avatar
I remember having to do that. I think it's two little tabs on the sides that have to be pushed in or pulled out. If you pull hard enough it'll pop out.
If you google 'audi a4 brake light cover' you can see where the tabs are and hopefully that'll help with the placement of your hand. In fact now that I do it, it looks like the tabs are on the bottom/back? Maybe just getting a flat screwdriver in there and prying up?
Old Jan 26, 2016 | 08:21 AM
A4TurboGuy's Avatar
There's no special way to do it. Just grab the sides firmly and pull back on it. It will pop off.
Don't forget to unplug the harness from the trunk before you replace the bulbs.
mikeeboy82
Jan 25, 2016 12:02 AM
kriptonik
Jan 15, 2009 09:10 PM
sbock
Jun 17, 2008 10:55 AM
MiniSpdRcr
Feb 2, 2008 09:12 PM
