thumping under moderate braking
Old Jan 20, 2011 | 04:13 AM
  #41
Boober's Avatar
FACKKKK... I thought it was fixed but the sound comes and go's now.
Old Jan 21, 2011 | 12:53 PM
  #42
Boober's Avatar
here's a recording of the sound i made while driving last night, sound is coming from only the right side
http://www.youtube.com/watch?v=Am5zCvnvldY
Old Jan 21, 2011 | 01:15 PM
  #43
Devildub's Avatar
That sounds shitty, were kinda having a debate about it but thinking ABS is malfunctioning or bad CV joint. The ABS I've herd of but the CV is kind if a long shot.
Old Jan 21, 2011 | 01:22 PM
  #44
Boober's Avatar
you think the abs could only be affecting one side?
Old Jan 22, 2011 | 03:46 AM
  #45
A4Money_pit's Avatar
Thats to weird, thats the same EXACT thing my a4 does, in my case, it only does it after I do a pull in the car, but its the same noise from the passenger side and I have a brand new ABS control unit etc.
Old Jan 22, 2011 | 06:49 AM
  #46
Devildub's Avatar
There's an ABS sensor in each hub, I'm also thinking the traction control might be thinking that wheel is slipping while under moderate braking and assisting.
Old Jan 24, 2011 | 12:09 AM
  #47
Tweaked's Avatar
Have you tried with blank rotors? Slotted rotors are useless on the street and tend to just create noise. I'd go thru and re-read the thread, but I'm on my mobile so it takes too long. Other suggestions are axle or loose caliper slides. Also check your ball joints and tie rod ends at the spindle for play.
Old Jan 24, 2011 | 12:19 PM
  #48
Boober's Avatar
everything on the calipers tight... im leaning toward an issue with the axel
Old Jun 17, 2015 | 02:31 PM
  #49
Matti Hautaniemi's Avatar
Hello, did this issue come to a solution? I'm having the exact same problem on the left front. Brake rotors are very rusty, removed rust from both sides but the problem persists.
sony
Sep 24, 2013 07:49 PM
fabric8
Jul 17, 2013 03:09 PM
Rdssk8boardr69
Jan 27, 2008 11:19 AM
Borden
Jul 23, 2007 08:29 PM
travsearle
Jan 26, 2007 09:42 PM
