Timing Belt Issue
Old Feb 11, 2011 | 08:32 PM
96BlackA4's Avatar
Default Timing Belt Issue
So this is the first time i've changed a timing belt and i kinda screwed it up. I took off the old belt and aligned the 2 cams manually to the marks. I never marked the crank pulley and moved it and now i have no idea how to align all 3 of them.
I put together the car not knowing and tried starting it and it didnt start so then i took it all apart again and read what dumb mistakes i made...
is there any way of aligning all 3 of them??
Old Feb 11, 2011 | 08:48 PM
02A6Beau's Avatar
helps to know what engine we are talking about. I'm assuming one of the 6 cylinders since you mentioned two cams.
anyway, good news is that you can probably get everything lined back up pretty well, when the belt if off, line up the cam gears by turning the so that the large holes in the "wings" are toward the center. make sure they are dead on with the cam lock tool or at least a good straight edge. There is a small tick mark on the crank pulley (not the timing belt sprocket but the v-belt pulley) that lines up to a tick mark in the center of the "window" in the 1 o'clock position on the crank sprocket cover. When yo see it it will make perfect sense. Then the cams and crank should be aligned at TDC. Then you can put the timing belt back on.
Now the bad news....
if you tried to start the engine out of alignment you may have "crashed" the pistons. bye bye pistons, bye bye valves. There is a possibility that it is OK, try lining everything up and see how it goes.
keep us posted.
Old Feb 13, 2011 | 07:20 PM
96BlackA4's Avatar
ya it took me a lil while to get what u were talking about had to reread your post a few times... but thank you sooo much put it all back together and she runs greaat
luckily none of my pistons were crashed and now its going to be time for me to get a new catalytic converter to pass emitions next month lol
does anyone know of a cheap place i can find a catalytic converter for a
96 a4 2.8 v6??
Old Feb 13, 2011 | 07:35 PM
ImTheDevil's Avatar
Best bet is a car being parted out in the classifieds on one of the various Audi/VW forums.
Old Jun 21, 2011 | 03:59 PM
guestsa's Avatar
Default "audi discount parts"
these guys seem to have a great audi parts supply.
other wise google on "AUDI DISCOUNT PARTS"
Subarashī Kao
Jun 21, 2014 09:00 AM
MichaelBaker
Oct 28, 2013 10:04 PM
george1546
Jan 6, 2013 09:16 PM
2001A4T
Jan 18, 2011 06:20 PM
chagnobu
Feb 23, 2010 02:06 PM
