Timing belt rubbing back of belt fan bracket
Old Jun 18, 2008 | 10:38 PM
TheBat's Avatar
Default Timing belt rubbing back of belt fan bracket
When I removed this bracket to change my timing belt I noticed the belt was rubbing on the back of the bracket, where the shaft cap is.
I shimmed it out a little bit, and know I noticed its rubbing again, but worse. I just had an issue with the pulley partially sliding off the shaft due to a locked up fan clutch. I'm wondering if the shaft is heading the other direction, out the back of the bracket? This is all I can think of, the belt is aligned with the cam gears.
Anyone ever heard of or seen this?
Old Jun 20, 2008 | 01:14 PM
TheBat's Avatar
Default RE: Timing belt rubbing back of belt fan bracket
Bump ttt bumpety bump
Timon
Jul 7, 2012 01:29 AM
M3Armand
Aug 15, 2009 10:19 AM
shaf
Jan 9, 2008 04:02 PM
