Torx bolt on #7 Cam Bearing cap is &$#}~%%!
Old Feb 25, 2012 | 02:37 PM
shipo's Avatar
Default Torx bolt on #7 Cam Bearing cap is &$#}~%%!
So I'm doing the Cam Chain Tensioner Seals on my son's 1998 A4 Quattro 2.8 and I'm having a heck of a time coming up with a T-30 driver which will fit between the lower Torx bolt on the right side #7 Cam Bearing cap and the body of the car. Are there right angle Torx drivers (ala allen/hex keys) available on the market or do I have to jack or tilt the engine to make enough clearance?
Any suggestions would be greatly appreciated.
Old Feb 25, 2012 | 02:59 PM
M5S5's Avatar
Tech Certified
Any chance you could provide a photo? If i have a look i could probably recommend something for you.
I don't remember the body getting in the way of that job off hand.
Old Feb 25, 2012 | 03:23 PM
shipo's Avatar
Default Pictures
Thank you for your willingness to have a look-see.
It's kind of hard to get in there well enough to give perspective; I can E-Mail you the full sized shots if that would help. You can PM me at shipo [put the "at" sign here] yahoo.com.
Attached Thumbnails Torx bolt on #7 Cam Bearing cap is &$#}~%%!-dscf3606-arrow.jpg   Torx bolt on #7 Cam Bearing cap is &$#}~%%!-dscf3607-arrow.jpg
Old Feb 25, 2012 | 03:57 PM
M5S5's Avatar
Tech Certified
I use the stubby 1/4" drive socket for them. I have VIM tools pn:hct1050-03.
The set is very inexpensive.
Hope this helps.
Old Feb 25, 2012 | 03:59 PM
shipo's Avatar
Hope this helps.
I have a Torx socket set which includes a T-30 which is a 1/4" drive; apparently mine is too long for the job. Thanks for the help.
Old Feb 25, 2012 | 05:03 PM
jonbonesjones's Avatar
Moderator
take the torx bit out of the 1/4 socket and use a 1/4 open end on it.
Old Feb 25, 2012 | 06:43 PM
bshusted's Avatar
^ This.
Old Feb 25, 2012 | 09:43 PM
shipo's Avatar
Thanks guys, I actually got around to that solution on my own; tried a 7mm open end, too small, tried a 9mm open end, too big, couldn't find my 8mm open end so I tried my 1/4" open end, ahhh, just right!
Hot water
Aug 15, 2012 07:48 PM
chickeneater
Jan 30, 2011 10:07 AM
bob martin
Feb 24, 2008 11:51 AM
pyropenguin
Jul 24, 2007 11:35 PM
